Help! Text with Transistions
samstarb
Post by samstarb »
Hello, Im having a problem where i can't get text i have inserted to move with the transistion when i preview it? The background will move but the text just disapears?
Are you playing in Clip or Project mode? You can only see everything in the latter mode. Even then, it will not be a perfect rendering...
Post by Trevor Andrew »
How long is the text/title duration. :?:
If you are using the default then its 3 seconds, with animation it may be on screen for 1 second.
If this is the case extend/increase the duration of the text /title.
1 / Select the title in the timeline¡Xdrag the yellow trim bars.
2 / Select the title---- change the duration on the digital clock, below the edit tab.
3 / Change the default duration from File ¡V Preferences-Edit-Default insert image ¡V colour clip duration. Affects new titles.
Post by Black Lab »
And, the text and transition are completely separate from one another. Even though the text may be on top of the transition, they don't automatically sync up. Per Tevor's advice you'll have to alter the duration of either or both.
