codecs interfering with mpeg play on windows property
duckrogers
Post by duckrogers »
I have mpegs that I can no longer play after I installed MF. However after I uninstalled it, I am still having the same issue.
When I run "Microsoft Windows XP Video Decoder Checkup Utility" it still finds the codec files.
Suggestions, please?
duckrogers
This forum is uselss. No help on any of the issues.
Annoying.
MikeGunter
Post by MikeGunter »
duckrogers wrote:This forum is uselss. No help on any of the issues.
Annoying.
Yikes, makes me want to help.
Geez.
MikeGunter
Re: codecs interfering with mpeg play on windows property
duckrogers wrote:Hi,
I have mpegs that I can no longer play after I installed MF. However after I installed it, I am still having the same issue.
Have you tried to convert the files to another CODEC?
JoReneA
Post by JoReneA »
I'm not sure what your message means...you say:
Do you mean after you uninstalled it?
I have had some mpeg problems also after installing MF, but once I uninstall it, the problem goes away. It isn't so severe that that don't play at all, but they are distorted (stretched horizontally). And they don't start automatically like they used to. I've asked for some help and was sent a "mpeg fix", but in my case, it did nothing to solve the problem. Maybe it would work to help you. Try sending in a support form if you have a registered copy of the program.
