Dropped Frames??
Pflash
Dropped Frames??
I tries to use the "direct to disk" feature. What I want to do is transfer from VHS to DVD without editing, and in the best possible quality. My experiment led to goos audio, but choppy video. I have a AMD 2800 with 1 gig ram and two hard drives (I use the second 80 gig for storage. I don't know if I have DMA activated, just where do you activate this? I looked in the bios, but didn't see it there (saw that problem on previous post) Any suggestions would be appreciated!
Re: Update
What was current transfer mode set to? It should be Ultra DMA mode 4 or 5. Also, make sure that you are checking the correct IDE channel i.e. the one that has your capture hard drive connected to it.Pflash wrote:I finally found DMA settings and it is set for that if it's available. Maybe there is another setting to get rid of the choppy effect.
Hope this helps.
- Ken
