sydoz56 wrote:I have tried uninstalling and reinstalling !! making me mad, i have d/l'd the toolstandard.dll and that is fine but now
i cannot install the 12.01 patch/upgrade
i use 12, but when i try the patch i get the following
Could not load command library 'TOOLSTANDARD'. Unable to retrieve
command 'Mover'. The library could not be found, or the associated
resources could not be found, or versions did not match"
Firstly, try starting PSP while holding down the shift key, and click "OK" when you see a dialogue box asking if you would like to restore PSP to its default state.
If that doesn't help, it might be best to reinstall after a clean uninstall - use the instructions in
this Corel Knowledgebase article.
then i can't shut down psp have to use the task manager,it worked up until about a week ago, i dont want to do asystem restore either
thanks for any help
Do you use Norton 360? There is a bug in that program that causes PSPP X2, and some other programs including Outlook, to not close properly. Some people have had success with uninstalling then reinstalling Norton 360. Otherwise, you will need to keep using the task manager until Symantec fixes the problem.[/quote]
