I am unable to add the "exit" button to the main toolbar. It just places the "Info" button there instead. Is this a known bug? It's not hard to do, so I can't imagine I doing something wrong.
THanks.
WSC
Customizing the Toolbar: Can't Add "Exit" Button
With 8.6 (came with PI-12 or 11) on my WinXP machine I'm able to place the Exit button on the toolbar. Are you running XP or Vista? I don't have it installed on Vista, since it is not designed to work on Vista (except after installing the patch meant only for bundled versions with Sanyo PCs..)
When you add the button, do you first highlight the button on the left, then press the Add--> button to add it to the right pane? In the Right pane with the Exit button highlighted select OK...
I have XP SP1. I have version 8.5. The web site doesn't have any 8.6. Where did you find that? Anyway, yes, I customized my toolbar and am not a newbie. Each time I try to add the Exit button, I get the Info one....
http://ulead.com/pex/runme.htm
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:WSC wrote:I have XP SP1. I have version 8.5. The web site doesn't have any 8.6. Where did you find that? Anyway, yes, I customized my toolbar and am not a newbie. Each time I try to add the Exit button, I get the Info one....
http://www.ulead.com/tech/pex/pex86faq.htm
Perhaps a re-installation will clear the problem.
