V10+ looping video
V10+ looping video
can someone tell me how to make a looping video using Studio 10+ please?
I searched the Help files but cant see any reference to looping.
I wish to use for a tradeshow.
many thanks
Kerry
many thanks
Kerry
I will update system info asap
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
lancecarr
- ram: 12GB
Dang! That should have worked!
Can you let me know how you are creating this disc?
Did you complete the video, output to a new MPEG2 file then start a new project and go straight to the share tab and open the burning module? And after that did you select the newly created MPEG2, insert that and let it burn making sure the "repeat" button was checked?
If you didn't could you do that for me?
Also what kind of discs are you using to burn on? If you are using RW you might want to try an +/-R.
It should work that way, but it doesn't.
Seems that is a bug that was never addressed.
Most, if not all, DVD players have the option to repeat a chapter, title, or disc. I simply use that to continuously play my video.
Jeff
Dentler's Dog Training, LLC
Hi Lance and Jeff
I love a plan that falls over
I am using an avi file I created from the original capture. This is how I burn all of my films and I usually have no issues.
I normally use Avid software however it has an issue so thought I would simply use U10+ to create the DVD. Ho hum.
I only ever use Tayo Yuden masters, not oem, so never have a media issue.
So the long and short is I can't make a looping DVD with uLead 10+. What about 11+ - does this do the job?
thanks
K
thanks
K
lancecarr
- ram: 12GB
In the Preview before burning, does your video auto repeat? I tried this with both VS10 and 11. They both auto repeated. Sadly I'm away from home and do not have any DVDs with me to burn to, and I don't have a stand-alone DVD player to test it on.
Did you uncheck Create Menus? I think this will only work if you don't have any menus, however not sure as I've never created a DVD without a menu...
I must admit I didn't sit through the 58 minutes to check this so don't know.
There were no menus done and I did not have Create menus checked.
thank you for your thoughts
Anyone from Corel listening can you let me know how to fix the bug associated with this issue?
One of the first videos I ever made with v10+ I wanted to have loop, but I couldn't get it to work. We discussed it on this forum and it was determined that nobody could get it to work. Sorry, but I don't have the time to search for that thread for any more details.
Like Lance, I do not use v11, so I'm no help there.
Jeff
jpmorgan49
- Hard_Drive_Capacity: 2TB
Kerris wrote:Thank you all for your input and time taken to respond.
Back to the drawing board for me to try to solve this one another way.
cheers
Kerry
Black Lab wrote:Most, if not all, DVD players have the option to repeat a chapter, title, or disc. I simply use that to continuously play my video.
Jeff
But it will go into a DVD player? And that DVD player most likely has a repeat function? I don't understand the problem.
Jeff
