Hi Trevor
The software version as far as I am aware is the latest available 11.5(plus)- purchased from Amazon. I assume therefore that it comes with all the latest updates? I did try running the utilities installation for the Indeo driver (whatever that is) but I got a message that there was already a later version found on my pc so I aborted the installation. (I have also tried un-installing and re-installing VS without any success so far as the movie-manager-template is concerned).
I have made some progress insofar as I created yet another mpeg file using the stadard DVDPAL template at 9600 kbps. I started a new project and inserted the new file as suggested into the time-line. Then, thinking that this might be straightforward I tried burning the DVD by reducing the bit-rate down to 5700 kbps at the burn stage (in order to get the file small enough for it to fit on the standard size disk). I did this reduction under the 'gearwheel' icon in the burner module. What I hadnt appreciated was that the file would then be re-rendered yet again so, two and a half hours later, the file did indeed write to disk. Unfortunately it is a wedding video with quite a large amount of dialogue and I have now found that part-way into the movie lip synch has been lost. So although I have succeeded in burning a disk the results are currently unacceptable. This is really disappointing as I'm concerned that I will now have to start from scratch and re-edit the whole video to replace the clips with the defective lip-synch. Frustratingly, I believed that I had already sorted out the template issue using the trial version before it (prematurely) expired. Unfortunately I cant now replicate this but I do really need to sort out the template issue before I try saving any further files.
I'm sorry to keep troubling you with this problem - not helped by my limited IT knowledge - but I would appreciate any further pointers
Andy
Trying to save completed project in useable format
Hi Andy
Indeo driver
Can you uninstall the version on your pc then re-install from the VS 11 disc.
I think this is worth a go.
Your wedding project.
How long is it. I assume it to be 90 minutes.
From the finished project you have to create a video file. We tried to use make movie manager, without success. (But haven¡¦t given up on that one.)
With the project open and showing in the timelines , Share Create Video File.
Select¡XCustom
Select¡XSave type as¡XMpeg files
Select ¡V Options¡XCompression tab¡XMedia type¡XDVD-PAL
Edit the remainder to your Mpeg properties, except for the Bit Rate. 6000 will give you 90 minutes of video.
That¡¦s why I ask, how long is the project.
From the Ulead Video Studio tab¡XUNCHECK Perform Smart Render.
Disabling Smart Render may overcome the audio out of sync¡¦ problem.
Select OK
The properties you have set can be viewed in the ¡¥Save options¡¦ panel.
This is what I see:-
MPEG files
24 bits, 720 x 576, 25 fps
Upper Field First
(DVD-PAL), 16:9
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 256 kbps
Give the file a name and a ¡¥save in¡¦ location.
Press OK and it will render the project to a new video file.
When its completed the process a video file (Mpeg 2) is saved to the hard drive.
Start a NEW project¡XShare Create Disc-the burner module opens, no video files.
Now Add your new video.
Create a menu and burn to disc.
When you finally hit the ¡¥burn button¡¦ the first thing you should see on the blue progress bar is ¡¥Convert Menu¡¦
Indeo driver
Select¡XCustom
Select OK
MPEG files
Upper Field First
(DVD-PAL), 16:9
