Aspect ratio in rendered file
jander
Post by jander »
Hello everyone; my first time at this forum.
I'm trying to string together 4 x 110MB mpeg-4 files (4:3) and render a blu-ray file at 16:9. Not having any success. All the switches in VS 11.5.0157.2 Plus are set to 16:9, from the flash screen to "Make a disc" yet the preview plays in 4:3 as does the playback from BD-RE. Inspecting the output file summary in "Make a disc" confirms 16:9 yet for some reason 16:9 never happens in the rendered file. What am I missing?
Second question. I was unable to find web site manual help on blu-ray procedures. Does this exist or is it imminent?
Nice forum. Pleasure to read.
randazzo
Post by randazzo »
Ok so according to your post your video shows in 4:3. Does the image look pressed from the sides on your tv screen? If so you should force your tv screen to play in 16:9 mode. That's the case with my TV set.
Jean-Pierre Randazzo
Post by Trevor Andrew »
Hi jander
From the timeline select the 4:3 clip then Attributes tab.
Tick the ¡¥distort clip¡¦ radio button
Right click the preview screen
Select Fit to screen
Right click again and select Keep aspect ratio.
Your 4:3 should fit the 16:9 screen
You will loose some detail top and bottom.
See ¡¥16:9 A look at widescreen¡¦ from the link below
Shows what 16:9 should look like using VS.
jander
Post by jander »
Many thanks for your prompt replies.
Good advice and I now have a 16:9 rendered file from the 4, mpeg-4s.
Thanks again.
