WinDVD 9 missing hdmi audio out
Moderator: lata
magnusr
Post by magnusr »
Got a new ATI 4850 card. Connected through my onkyo 805 receiver using hdmi. Using PowerDVD 8 im getting LPCM 5.1/7.1 from blu-rays, and DTS/DD from DVDs.
Now using WinDVD 9 there is no HDMI selection. Tried to set it to 6 speakers but i get no audio. Please help. Need this software working to watch HD-DVDs.
Thx in advance.
oddius2008
Post by oddius2008 »
I'm presume you meant WinDVD 9. Have your enabled hdmi as your main audio device from the control panel?
magnusr
Post by magnusr »
oddius2008 wrote:I'm presume you meant WinDVD 9. Have your enabled hdmi as your main audio device from the control panel?
Yup was a typo, it has been corrected.
Yes its default. Its my only audio device since onboard is disabled.
magnusr
Post by magnusr »
bump :shock:
Which version of WinDVD 9
Standard
Plus
Plus Blue Ray
magnusr
Post by magnusr »
WinDVD 9 BD Plus with the latest update: DVD9.0.14.91_63207_Plus_iUpgrade.exe
I can only choose 2-6 speakers (no hdmi or spdif). I do get audio choosing f eample 6 speakers. But windvd then gets LPCM 5.1 wrong. Plays it as stereo. Go figure.... AC3 is correct.
ATI 4850 Catalyst 8.8 (Using Realtek HDMI 2.0 driver).
DirectX Latest
Vista X64 SP1 all updates to date.
magnusr
Post by magnusr »
Its the same with Realtek ATI HDMI Audio 2.03 driver also.
Works perfectly in PowerDVD 7.3 Ultra and PowerDVD 8!
kweller
Post by kweller »
FWIW I'm having a very similar issue. I've just downloaded and installed the trial version and am only offered 'headphones' or '2 speakers' as my audio options not HDMI which is my default audio output device.
There's another effect - I run Windows Media Center and the sound, coming through the HDMI port to an amp, is fine. Start WinDVD and MCE sound disappears, close WinDVD and the MCE sound is back again.
Edit: Oh, I forgot to add - this is my first post so "Hi".
Kevin
Johnny B Richman
Post by Johnny B Richman »
magnusr wrote:WinDVD 9 BD Plus with the latest update: DVD9.0.14.91_63207_Plus_iUpgrade.exe
DirectX Latest
I do have the very same problem e.g. although I do see "6 speakers" in Audio options in WinDVD even if I set it to 6 speakers I hear only stereo sound. Talking about Blu-ray playback of the uncompressed 5.1 audio track. Dolby Digital 5.1 on Blu-ray works fine.
I have the latest WinDVD 9 Plus Blu-ray patch installed 9.0.14.119 (67214), ATI Radeon 4850 (Gigabyte GV-R485MC-1GH) with latest Catalyst 9.2, Vista 64-bit Enterprise SP1 with latest automatic updates, latest drivers from Realtek (Realtek Vista Driver 2.17 & ATI HDMI Audio Device 2.13).
I also do have PowerDVD Ultra 7.3 (came with my LG Blu-ray / HD DVD drive) and there it works fine e.g. I can hear 5.1 LPCM sound with no problems at all.
I also tried Windows XP (Pro SP3) and to my surprise in there playback of 5.1 LPCM in WinDVD works fine!
I encountered also another weird problem regarding sound on my system (all of you with similar setup please try if you can) and it's related to playback of DTS 96KHz/24bit audio track -> it does not work. I mean once I switch to this track (mostly to be found on music DVDs) I hear no sound at all and on my receiver's display I see flickering e.g. it apparently tries to handshake with my HTPC however it fails. Normal DTS and Dolby Digital tracks play fine with no problems. I tried to check / uncheck "Enable 96/24 decoding" in settings -> no difference.
Again PowerDVD Ultra 7.3 plays those DTS 96/24 tracks fine (my receiver shows DTS 96/24).
And again in Windows XP WinDVD plays those fine too - that's why I assume these issues relate one to each other.
Johnny B Richman
Hmm so much for the feedback? Feels good indeed :roll:
OK so here's the news: today I updated to latest build B14.132 (74098) and to my (positive) surprise DTS 96/24 now plays fine in Vista!!
So being in that pleasant mood I tried Blu-ray playback and to my (negative) surprise it does not wok at all = I mean whatever audio track I select when playing Blu-ray disk I hear nothing AT ALL no matter if I select PCM or Dolby Digital track!! Strangely enough I can hear menu sounds = when going through disk menus.
So all in all (at least for me) Corel managed to repair one issue and brought another one so now I am unable to play Blu-ray disks completely!!!
I tried also my XP partition and there everything works fine with the latest build as it did with the previous one.
Anybody else with similar (or even the same) config? Does it work for you?
lesterf1020
motherboard: ASUS P8P67 DELUXE
processor: Intel Core i7-2600
Video Card: Amd HD 6970
sound_card: Soundblaster X-fi Titanium
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: Acer AL2216W & Samsung PX2370
Post by lesterf1020 »
I had the same issue as you with the sound and I resolved it by changing the Audio renderer in the Audio setup. After changing that I got my sound back and you can then change it back to its original setting and it will still work.
"History does not repeat itself. But it does rhyme!"
Elst
HDMI Out on Win DVD 9 Plus Blu Ray
Post by Elst »
Hi Guys,
'Been reading your posts with interest.
I had similar problems when I installed the Asus Xonar HDAV 1.3 sound card on my HTPC and, try as I might, I just couldn't get a sound I was happy with. After a few hours of messing around and reading numerous posts on the myriad of forums I learned the following: You don't necessarily need an HDMI Out option on Win DVD 9 Plus Blu.
And before I go on, let me say that not all HD sound tracks on BD are equal. Hell no! The Dolby True HD track on Iron Man is terrible! However, the Dolby True HD track on Cloverfield is excellent! Why is there a difference? You tell me.
All my devices are interconnected via HDMI 1.3 cable. My o/s is Win XP 32 and the first thing I learned is that Win XP only likes its digital sources in stereo. As soon as I configured 2 Speakers in the Xonar control panel everything sound wise snapped into focus. I'm guessing something similar will apply in Vista or Windows 7.
The other thing that occurred to me is that some discs allow you to use Win DVD 9 Plus Blu to decode the multi-channel source then pipe it to your amplifier(s). Some discs don't.
For instance I always have trouble with Dolby True HD. My amp says there's an HD source and I suspect the amp isn't decoding that source. DTS Master Audio however is very, VERY different. Some BD's with DTS MA allow you to pipe the source (via Win DVD) to your amp and allow the amp to do the decoding and I have to say it sounds bloody wonderful. To be fair, both Dolby and DTS sound very good indeed.
I suspect that some folks want the HDMI Out option to allow their amplifier(s) or AV Receiver to decode the LPCM or PCM bitstreams. If I understand things correctly, you'll only be able to do that if your BD's have those options. Like I said earlier, not all BD's are created equal.
I may be wrong of course.
Before I go then, let me just say that I've spent the last 10 years with SPDIF and 5.1 audio so my knowledge of HDMI and HD audio is limited at present. I'll pass on what I learn.
Thanks for listening.
Elst.
:D
The Force Is With You Skywalker, But You Are Not A Jedi Yet.
danie53595
motherboard: Intel915
processor: 3.6GHZ
Video Card: Intel Inside Chipst
sound_card: Sound Blaster
Hard_Drive_Capacity: 1TB
Re: WinDVD 9 missing hdmi audio out
Post by danie53595 »
Thanks for sharing this post. This is a very helpful and informative material. Good post and keep it up.
Elst
Post by Elst »
Danie,
You're very welcome.
In fact I've learned much since my last post. When I get a chance I'll update all.
Enjoy.
Elst.
