Blending
patmart
Blending
Post by patmart »
PhotoShop has a tool caked ¡§feathering¡¨ for use in smoothing edges when blending two objects. Does PI have a similar tool and if so, how do I access it?? Thanks!
Pat
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Object>Properties>Soft edge for objects or
Selection>Soften for selections
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: Blending
Post by trueblue »
patmart wrote:PhotoShop has a tool caked ¡§feathering¡¨ for use in smoothing edges when blending two objects. Does PI have a similar tool and if so, how do I access it?? Thanks!
Pat
You can use the Blur Tool, found in the Toolbar on the left Retouch Tools.
To blend/blur you will have to increase the transparency to around 90-95 and lower the level to 1 or 2, then blend gently your edges. If it's an object you are blending/smoothing, click on the 'Edit Active Objects Only' - this is an icon on the Attribute bar that has a fade square and dark circle. This enables you to only blur/smooth the edges of the particular object you have highlighted. Of course, if it's an image, the you would use the other tool, Paint as an object, this is the tool that looks like a lightening strike.
It also enables a layer (look in the layer manager) if you make a mistake it can easily be deleted.
Hope this helps :)
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
patmart
Blending
Post by patmart »
Thanks Maurene
Pat
