I Found a Solution...ufo files / Vista / PS12
gebirgsjager
Post by gebirgsjager »
I had all of the same symptoms I read about in my search on this forum...couldn't open, move, delete, or rename ufo's. Trying to do anything with them caused PS12 to freeze up (on Vista).
I was just playing around and hit the browse button under file instead of open. I found my ufo's and ..that did it. For some reason the small thumbnail image appeared for all of them and I was able to delete, move, rename, and most importantly, open the ufo's.
I tried to open them again using the File and Open commands, and it didn't work. PS12 crashed.
So, if you're having the common .ufo problems with Vista, try to open them using File and Browse instead of File and Open.
Best,
Blair
I'd give my right arm to be ambidexterous.
gebirgsjager
One little glitch. I was able to delete ufo's no problem using the method above. But once they are in the Recycle Bin, I can't delete them from there.
gebirgsjager
Well, I seem to be having this conversation with myself.
If anybody is reading this thread who was in the same boat I was, this patch works perfectly. It clears up all of the ufo problems, even though it is not listed as one of the fixes.
http://www.ulead.com/tech/pi/pi_ftp.htm
Glad I came here looking for help...
