MOVIE WIZARD : Creat disc; Preview Problem
soloman42
Post by soloman42 »
after adding still images to movie wizard I select slideshow and after adding a theme template it plays ok in the preview box, however after selecting "create Disc" and preview the movie in the preview box the movie seems to have a slight "Jerk" in between images "ie. doesn't run smoothly as it should." why would this be
happens in vs10 and vs11. I have windows xp sp3 all latest updates include directx, Pentium D with 1GB Ram 250gb hdd
Thanks for your help
Post by Black Lab »
Jerkiness is sometimes the result of using the wrong field order. Please read THIS POST that is found at the top of this forum and supply the requested information.
The only problem with the incorrect Field Order theory is that this is a slideshow, which is inherently Frame Based but can also be either Upper or Lower Field First with no problem.
Also, the jerkiness seems to be between the images. However, it is not clear whether soloman has used transitions between each photo and the j*rk occurs during the transition, or whether it is a straight move from photo to photo without transition -- in which case I would have thought a minute blip would be the norm??
Unfortunately, I have never used the Movie Wizard so cannot offer any specific help with that. My only suggestion would be to try making the slideshow in the Editor module and see if the problem persists.
Also, have you actually produced a DVD? If so, is the blip apparent there? I ask because the VS preview is really only to give you an idea how things look generally. And things more often than not look a lot better on the final DVD than they do in the preview screen... :roll:
Post by Black Lab »
You are quite right, Ken. I totally missed the point that he was using still images. :oops:
soloman42
Post by soloman42 »
hey guys thanks for reply; in response to ken; yes iam using the automatic transitions which 'movie wizard' makes. I have also tried straight in video editor and still happens and yes after creating disc and play back in any dvd player still jerks. Also should note that smart pan & zoom effect is applyed with transitions. How do I change field order I will try that
soloman42
Post by soloman42 »
I find that if pan and zoom is not applyed and transitions are it is ok, hoever I like to use pan and zoom effect to slideshows. It makes the presentation more interesting.
