VS 11+ Create Menu for project
tt2ride
motherboard: Gigabyte
processor: Intel QuadCore Q9300
ram: 4GB
Video Card: Nvidia GTS 450
sound_card: Integrated
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: NEC
Post by tt2ride »
I need help with VS 11+ creating menu.
I took this path to get to the menu section
>Share>Create Disc-DVD>Gallery
-Is there a way to customize the text on the menu? e.g. add more text besides what was available from the templates.
-Can I save the template so I can re-use?
-Is this the only way to create a Menu?
-I can change background music, image and font, but nothing else.
Thanks!
Post by Trevor Andrew »
Share Create Disc.
From the Edit Tab
Click the text on preview screen to select text box, then select Font Settings ¡¥T¡¦
Double click the text to edit content.
Use the Customise option to change some options, depends on the type of menu chosen from the gallery.
After completing the menu ¡¥Close¡¦ the window.
Now Save the project again using File ¡VSave As or Save this will preserve all menu.
Open this project at a later date Share Create Disc and the menu structure should be there.
If you went Share Create Disc from a project, that is with timeline content and you continuing editing then the menu structure may mess up.
You are best Share-Create Disc from an empty timeline, then ADD video.
tt2ride
ram: 4GB
Post by tt2ride »
Thanks Trevor.
Let me try this tonight. I usually Share>Create Disc from one timeline project and then add more VSP to it to create the menu. I cannot remember seeing the File>Save As option.
Can I add more text to the Menu? I would like to include the title, date, comments, etc to the menu and able to save it for future use too. Please help.
Thanks.
