Exporting Captured images from Video Studio 11
Quin333
Post by Quin333 »
Hello Everybody
I am using Video Studio 11 +, I have captured some wedding footage of my friends wedding and have save some frames as images, which sit directly into the image library.
I want to export them out of VS11 + so I can manipulate them in photoshop and then print, the only way I can see to do this is to print them from VS11+ and then scan them in at a high realution into photshop, but this seems rather a long winded way to do things, can somebody tell me how to do it or is this not a function in VS11+?
Thank you very much in anticipation.
Post by Trevor Andrew »
Not sure I understand.
The images in the library are only a thumbnail a virtual clip representing the actual file on the hard drive.
If you right click the thumbnail, select properties, the file name includes the location on the hard drive of the actual file.
Example:-
c:\program files\ulead systems\ulead videostudio 10\samples\image\i08.jpg
You can open this image file using photoshop, once you resave the image you may have to re-link in VS.
Quin333
Post by Quin333 »
Hello Trevor
Thank you for your reply, I will try this and see if it works for me, I have done a search on my HD and looked in the Ulead directory for the files but perhaps I am lookinf for the wrong format.
Regards.
Quin333
Well, in File > Preferences > Capture, you can save images within VS as either .jpg or .bmp. And unless you have changed your working folder, it will be in [My] Documents > Ulead Video Studio > 11.0.
From the image library, right click an image and select "Properties"
On the General tab you will see file name.
Drag your mouse over it with the LEFT mouse key held down to highlight it.
(You cannot always see the complete file name due to the fixed width of the dialog box - when you wipe over the name the rest will be revealed)
With the complete file name highlighted, RIGHT click the mouse and select copy.
You can now either paste that into notepad, or simply open your favourite image editor and when you select open image just paste the file name in.
Hi Quin333
As Ken mentioned, your captured image files are saved to your working folder.
For future work, it may be best to create a new working folder, one for each project.
Your captured video and image files will be saved there.
Just to add to Steve, once you click the file name a curser is placed there, you can move the curser using your keyboard left/right arrows revealing the file name.
Quin333
Thank you sorted
Post by Quin333 »
Thank you everybody who responded to my problem, it is now sorted and I have seperated all the files I wanted to a different directory to work on them.
I had been searching for jpg's but it had saved them as bmp, anyway all is well, thanks again.
regrads.
Quin333
You can change the Jpeg / Bmp option in File Preferences / General Tab
Quin333
Post by Quin333 »
Thanks again, Trevor.
Actually, as I already said, it is File > Preferences > Capture (i.e. not General) tab...
Oh dear, sorry about that, I even looked and doubled checked the option.
Thanks for the correction Ken
