Hopefully someone will be able to help. I¡¦ve looked through the forum for a possible solution but not had much luck.
My problem is with creating a HD Video File with VS11.5+. The 10 minute video is jerky in places and when I look at the video file created (MPPEG2 file) I can see that a few frames have been duplicated and the correct few frames skipped.
I¡¦ve been creating the video file (HD Mpeg2 1400x? ¡V same as the source files after a few simple cuts) and then converting it to an AVCHD file for playback thru my PS3.
The original source file has all the frames. If I step through them one by one on the timeline I can see then perfectly.
Everything I¡¦ve tried. Eg. All the options for HD MPEG create the same video file with the same stuttering problem at the same points of the video. With/Without MPEG Optimiser, or using ¡§same as Project settings¡¨ and/or switching the smart render off too.
I¡¦ve tried just creating a 10 sec video file for just a selected portion that I know was bad and it always creates a jerky video.
Creating a SD Mpeg gives a jerky video too. The only video that creates correctly is to a SD DV (AVI) file!!
Details:
Source files are from a Sony HC5 HD on DV tape, firewired to my PC.
My PC has a XP2400+ Athlon CPU with 1.3Gb RAM . I know it¡¦s not the ideal spec for HD video editing but it does seem to work generally ok.
VS11.5+ properties :
Under File->Preferences | Edit tab -> Resampling Quality = BEST
Project Properties Are (same as source MPEGs):
Compression Tab First:
Media Type = Mpeg2
Quality = 100% (Does leaving it at 70% make a difference ?)
Two Pass Encode = OFF
Video Data Rate = Constant bit Rate (CBR = 25000)
Audio = Mpeg2, 48000, Stereo @ 384kbs
General Tab:
FrameSize = 1440x1080
FrameType = Upper Field First
FrameRate = 25(PAL)
Ulead Video Studo Tab:
NonSquare Pixel Rendering = ON
Audio channels: = Stereo
I did forget to set the project settings as above until after I had first seen the problem. So I would have been editing my video with the default project settings. Is this the cause? Do I have to start from scratch?
Much appreciated for any ideas¡K. My brain hurts !
Cheers...
