After I upgrade my windows to vista I see I cannot make a dvd from divx files.
The problem is during burn progress. it stopp and a popup windows shows that I have to close the program.
I see these logs
Problem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 11.0.0.0
Application Timestamp: 46e518ea
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a7a6
Exception Code: c0000005
Exception Offset: 00043590
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 5fca
Additional Information 2: 22f6e51a7fc1a83a1797ac290773f310
Additional Information 3: e728
Additional Information 4: 6510ba9a6e3b5c989948c16136e164c9
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
How can I fix this issue?
Problem Make DVD from avi file
Welcome to the forums,
First did you download and install the DivX codec? This must be done manually, as it is not provided with Windows or VS. You can get it HERE
Just a side-note, DivX (Xvid is the free, open source version) was designed for distribution (viewed via the internet), and not for editing purposes. So any editing of highly-compressed formats is going to be tricky, and there will most likely be some quality degradation, with each recoding.
Unless you have a stand-alone DVD player that is DivX certified to play DivX files, AND you use DivX Author to create your DVD, your video must be converted to DVD specs, which only allow MPEG-2. Your workflow will determine success or failure here.
If you are using DivX files in your project, and you proceed directly into the burn module from the editor, all the DivX video clips will need to be converted to DVD Compatible MPEG-2. This is done in addition to and while also trying at the same time to create the menus, chapters, ect, for your DVD. This is a very big task for your computer. So what is suggested is to convert the video in the editor (Share>Create Video File) before proceeding to the burn module (Share>Create Disc).
Ty for your replay.vidoman wrote:Welcome to the forums,
I installed Divx Codec. and by your direction I tried to make MPEG2 file before make DVD. But I cannot preview the file after I change sound to 5.1 and also the MPEG 2 file I created has no voice.
Like I stated above working with highly compressed files such as DivX can be tricky, which you're certainly finding out. I don't use DivX compressed files to edit. I start with DV (avi) files and then if I want to upload them to the internet, I may choose DivX as my final output. I use the DivX Pro Package, which just provides a little more than the freebie, like the ability to convert MPEG to DivX.
The 5.1 Dolby Digital would not be supported in the free DivX package. Dolby charges a licensing fee to use it's technology. DivX, Corel or any other program is not going to give away what they have to pay for.
You might try converting the DivX files before trying to edit them using a free conversion utility called SUPER by eRightSoft.com. I've used it on occasion to convert files, and it seems to do a good job.
I checked again and choosed stereo instead 5.1 sound. But I think I ve some issue regarding to my VS11. because when I try to add chapter. I see the program terminated and I see these details in logvidoman wrote:Like I stated above working with highly compressed files such as DivX can be tricky, which you're certainly finding out. I don't use DivX compressed files to edit. I start with DV (avi) files and then if I want to upload them to the internet, I may choose DivX as my final output. I use the DivX Pro Package, which just provides a little more than the freebie, like the ability to convert MPEG to DivX.
Application Timestamp: 4762104e
Fault Module Name: mfMediaService.dll
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 469dd47e
Exception Offset: 00007172
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
- ram: 2 GB
- sound_card: Intel GMA 950
OK you started out with the "view only" DivX files.newdave wrote:.......
I checked again and choosed stereo instead 5.1 sound. But I think I ve some issue regarding to my VS11. because when I try to add chapter. I see the program terminated and I see these details in log....
What format have you converted them to (as per the advice already given by Ron).
Hopefully you have chosen MPEG2 which is the format necessary to create VOB files.
