HDV Split By Scene during Capture (Update)
jmone
motherboard: ASUS P8Z77-VPro
processor: i7 3770K OC
Video Card: ASUS GTX660 OC
sound_card: FiiO E10
Hard_Drive_Capacity: 60TB
Post by jmone »
The following is the response from Tech Support (about the same as the answer 6 months ago):
Q: - Do you know if (and when) VS11+ will support Split by Scene (using the timestamp) during HDV Capture - eg like DV?
A: - Thank you for your inquiry. Kindly be informed that there is no information yet on the release date of a Service Pack for VideoStudio 11 that will offer support to this issue. Thank you for your patience regarding this matter.
The simple answer is: sorry, don't expect a patch to VS11. They are working to release VS12, and it will interesting to see whether it is even included there.
I use HDVSplit which does the job quite nicely, and is free... :lol: Then I open the captured split files and edit in VS11.5+.
jmone
Post by jmone »
Hi Ken - Thanks - That was also my reading of it!
I know that HDVSplit is an option but I do like the PS files from VS11 capture over native TS from HDVSplit - but really - how hard can it be to keep a feature they have always supported....
Split by scene in successive versions of VS has only ever worked during capture in the DV format. It has, as far as I am aware, only ever worked *after* capture with DV and standard definition mpg-2. I agree, though, that I would not have thought it too hard to extend the latter to high def mpeg-2.
For what it is worth, I don't mind the TS aspect of HDVSplit as I in any case have to produce a final TS version of my edited HDV for sending back to the camera! :lol:
jmone
Post by jmone »
As I keep all my editied footage on a HTPC my preference is for PS....however I'll have a look at my workflow again as I'm going to need to do a heap shortly (I'm years behind!)
Nathan
jmone
Post by jmone »
Can anyone confirm if X2 (or any patch to V11) supports Split By Sceen (during capture) on HDV?
Nathan
No patch was issued for that in VS11, and X2 will not split HDV by scene either... Still a matter of using HDVSplit...
jmone
Post by jmone »
If that is the case is there anyway of do a batch TS to PS conversion (without transcoding) of the files created by HDVSplit?
Gisela Richter
Post by Gisela Richter »
jmone wrote:If that is the case is there anyway of do a batch TS to PS conversion (without transcoding) of the files created by HDVSplit?
Video Studio will split the scenes AFTER HDV capture without any trouble, I don't quite understand why you are not satisfied with this.
Kookaburra
jmone
Post by jmone »
Split by Scene during capture uses the changes in the Time / Date stamp to create a bunch of individual files that are then easy to add / remove etc.
Split by Scene after capture tries to determin changes in the "scene" and for me does a poor job. It also uses mark in / mark out not seperate files for each "scene". I'm sure it works for many but I'm used to the original way.
babyleon
motherboard: PEGATRON CORPORATION 2A86 1.04E01
processor: Intel Core i7 930 2.8GHz
ram: 12.0GB
Video Card: ATI Radeon HD 5450
Hard_Drive_Capacity: 7+ TB
Post by babyleon »
Perhaps it is my computer equipment, but for me, splitting after capture (by subject change) also takes a LOT longer, more than a minute for each minute of captured video.
lespurgeon
Post by lespurgeon »
I use HDVSplit to capture, then import the clips to VS 11+
Ormond Williams
Post by Ormond Williams »
I am new to HDV, but after taking Ken's advice on using HDVSplit, I'm very happy to continue using it! It works perfectly!
Ormond.
cgould
Post by cgould »
HDVSplit to M2T files, then import/edit those in VideoStudio, seems the best solution so far; I think only Vegas properly supports direct HDV scene-detection/splitting during capture.
However, VideoStudio is a bit slow working with M2T (hdv "transport stream" MPG2), both importing to the timeline/library, and also smart-rendering out to regular "program stream" MPEG2... VS X2 seems noticeably faster on this, especially if you add direct to the timeline rather than using the library;
but, smart-renders seem to take real-time (eg 10mins for 10min video), only 25% CPU, low disk usage. So there is some unwrapping/processing that takes place.
It's still much better I think than having a single large MPEG2 file and having VS do image-content-based scene detection.
For one thing, HDVSplit creates files named per the datestamp, so it's very easy to find exactly the file/clip you are thinking about, especially over multi-day/hour shoots.
It's also easy to re-capture any files again, exactly to the frame, without worrying about timecode etc.
I really wish VS X2 would support this directly, and faster...
