Mpeg 2 back to AVI
john booth
Mpeg 2 back to AVI
Post by john booth »
Can you convert Mpge2 back to AVI?
THoff
Post by THoff »
Yes. Go to the "Share" tab, and select "Create Video File", and use the existing AVI template, or choose "Custom" and tweak the settings as needed.
bobfrank
Post by bobfrank »
The end result, of course, won't be the same quality as the origial AVI video
THoff
Post by THoff »
Not necessarily.
First of all transcoding -- even between high-quality, high-bitrate formats -- results in slight encoding differences unique to the algorithms used. These usually show up in small scene details and near edges.
Also, MPEG2 is not a lossless format, and in the case of DVD-resolution video, it carries only about 1/3 of the data that DV AVI does, for instance. Furthermore, the AVI in question could be uncompressed, in which case MPEG2 would carry only 1/15th of the data of the AVI file.
Edit: my bad, I misread your post -- I though you wrote that it WILL be of the same quality. Sorry bobfrank!
bobfrank
Post by bobfrank »
Thanks for the edit to your reply. I was really getting confused reading your reply. I was starting to think I had no clue about what I was saying.
I'm not quite a newby, but I'm certainly no pro at this video stuff.
