Problem after install SP3 for Windows XP?
IronKokc
Post by IronKokc »
Hello.
I'm creating DVD-video project in UMF6plus (all patches and updates installed).
After adding files of the pictures or videos and the click Next button - show error message "Cannot create menu". Earlier on Windows XP Professional SP2 UMF6+ fine worked. Possible this has occurred after installing SP3 for Windows XP? That to do? Where can be a problem? Help me, please.
Thank you.
Post by Black Lab »
Make sure you have the latest DirectX from Microsoft. That's not usually included in updates (don't know about SP3).
IronKokc
Post by IronKokc »
Black Lab wrote:Make sure you have the latest DirectX from Microsoft. That's not usually included in updates (don't know about SP3).
DirectX 9.0c (4.09.0000.0904 Aug 2007) is installed and before SP3 all were OK. All drivers correctly installed. UMF uninstalled, manually cleaned folders, registers and installed UMF again. I'm try update DirectX and video-driver. About result shall write.
_______________________________________________________
Has Installed the last version DirectX and video-driver, but UMF+ does not work (Cannot create menu).
Beside anyone works with Window XP Pro SP3?
dhnj
Re: Problem after install SP3 for Windows XP?
Post by dhnj »
IronKokc wrote:Hello.
Thank you.
Hello
I too have installed SP3 for Windows XP, and there is no problems with UMF6plus when making a project.
Best regards
IronKokc
Post by IronKokc »
dhnj wrote: Hello
Best regards
Thank you.
Probably, it is necessary completely reinstall OS, possible the system files did not full reconstruction after malfunction electricity.
dhnj
Post by dhnj »
IronKokc wrote:
dhnj wrote: Hello
Best regards
Thank you.
Hello
If you completely reinstall the OS, you will then have to reinstall other applications too. You can reinstall SP3 again on top of what you right now. I have done this with SP3 release candidate and then the final SP3.
Best regards
