I bought VideoStudio 11.5 Plus and it will not run on my Vista Home Premium SP1 computer.
It gave ¡§the application has failed to start because its side-by-side configuration is incorrect¡¨ error, when I attempted to start it. Also during installation I received ¡§the installation of Microsoft Visual C++ 2005 redistributable SP1 package appears to have failed¡¨ error.
VideaStudio relies on the Microsoft Visual C++ 2005 SP1 Redistributable Package (x86). It was a part of the previous Windows operating system. VideoStudio forces Visual C++ 2005 SP1 Redistributable Package (x86) upon your system during its installation process. VideoStudio will not run without those ¡§old¡¨ Windows components.
I called Microsoft to ask why Vista prevents installation of C++ 2005 SP1 Redistributable Package (x86). I was told that the current Windows operating system - Vista - prevents Visual C++ 2005 SP1 Redistributable Package (x86) from installing, because it protects ¡§integrity of the current operating system¡¨. When I mentioned that the product in question had ¡§Certified for Vista¡¨ logo on the box, the Micsrosft rep wanted me to tell him what product I had. I chose not to tell him, because I did like VS 9 version that I used in the past on my old computer, and as a loyal Ulead customer in the past I did not want to create another issue for Ulead.
I called Ulead/Corel. According to Corel/Ulead Technical Support Representative Adam, VideoStudio will not run without Visual C++ 2005 SP1 Redistributable Package (x86). Upon his advice I tried to download and install Visual C++ 2005 SP1 Redistributable Package (x86) directly from Microsoft website. Vista again did not allow adding (installing) Visual C++ 2005 SP1 Redistributable Package (x86) to my computer. At that time Adam blamed it on Microsoft and informed me that his role ended. No options to talk to a supervisor and no option to complete Customer ¡§Satisfaction?¡¨ Survey , that was advertised while I was holding on the line with Corel/Ulead.
So it appears that if you have Vista as your original operation system you can¡¦t use Ulead VideoStudio 11.5 Plus.
If I had upgraded from XP to Vista I would have had those legacy old components and I would have been able to install VS11.0-->VS11.5-->VS11.5 Plus. Since my computer has Vista from the very beginning (not upgraded from XP) I can¡¦t use Ulead VideoStudio 11.5 Plus.
By the way, buying/downloading 11.5 Plus directly from Ulead still forces you through VS11.0-->VS11.5-->VS11.5 Plus journey. I was not charged for talking to Corel/Ulead tech support.
I am disappointed will Ulead. Amazon will not take it back for a refund, because I opened the box. They can only ship another box of the same product. I am stuck with non-working Ulead product and will have to look for video editing software that will work with Vista.
Any recommendations?
uhill
Read it if you consider VideoStudio 11.5 Plus and have Vista
I don't have v11.5 or Vista, but I'm sure this thread will get a lot of replies saying they have said version installed on said OS.
Jeff
Dentler's Dog Training, LLC
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Hi Uhill
I bought VS11+ an upgraded to VS11.5+ while I still had my old XP based system. At first I had trouble installing the MSVC++ but persistance payed off.
When I upgraded to Vista Home Premium 64 bit on a new system I don't recall having any problems installing in Vista. All necessary legacy files installed well.
I did right click on the setup.exe file on the disc and select "run as Administrator" and VS installed smoothly. I did a quick test, everything seemed fine then installed the patches in the correct order. Maybe that was the trick?
I have no problems running VS11.5+ on a Vista 64 bit system.
Then Vista SP1 came along. I installed it and everything was still working.
I guess I was lucky
I guess I was lucky
Ditto with my new Quad which came with Vista Ultimate 32 bit as its first and only OS. I installed VS11+ with no problem. I even seem to recall seeing the reference to it installing Visual C++ and thinking that it seemed a little strange that it was installing something from 2005 i.e. pre-Vista. But it installed and works fine. Followed the upgrade path to VS11.5+ and it continues to work fine. And I didn't install as Administrator!
Just a normal, straight install...
I successfully got 11.5 to work on vista 32 bit, however the program does not work on vista 64 bit for me. Just got a new computer and loaded 11.5 and everytime I start I get a message that tells me I have to run as administrator. I even tried to install by right clicking and installing as administrator. I try to create bluray disk and the program crashes.
Ok, did a search and tried this trick from this post:
http://phpbb.ulead.com.tw/EN/viewtopic. ... inistrator
Basically, right click on desktop icon, the select advanced and select run as an administartor.
