How to create PAL format video?
After i'm done with adding music and transitions to each of every clips, i wanted to convert them to MPEG2 PAL format. Yet, i only see NTSC when i click on "Create Video File". It's really weird. Do i miss out anything like plugin stuffs like that?
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Where do you live.???????????
If you are in the US then you should us Ntsc
If you are anywhere else (UK-Europe) then you probably would use Pal. (well mostly)
When you install Video Studio you are given the option to choose your location or Pal/Ntsc
This option creates the default templates. (easy to miss)
So where do you live???????
Also fill in the details in your forum profile.
Otherwise:-
As far as I know selecting ¡¥Custom¡¦ from Share Create Video File will allow you to set DVD-Pal.
Also
If you are using Pal-Mpeg files in your project ¡XSelecting Same as First Video should give the correct options.
Otherwise:-
Also
