When I capture a movie from DV, after stopping the capture process, a window appears and says "File Transfering...." it takes lots of time to being completed so then I can use the captured movie. Amazingly, this window hans't been appearing before but recently I see it!
How should I remove it?
File transfering after each capturing...
Hi Amin
To be honest I am unsure about the warning you describe, there are several that may pop up.
Unless you are seeing the ¡¥Emptying Trans-code Buffer Warning.¡¦
This is usually associated with a slow PC or slow trans-coding¡¦ but not with DV capture.
When you say ¡¥capture from DV¡¦ what are you capturing to. That is what do you see in the Capture Format box.?????????
Need a lot more info
1/ What make and model of Camera
2/ If you are using Video Studio, what version.
3/ How are you connecting the camera to the pc, hopefully ¡¥Firewire¡¦
4/ What format are you using to capture ( shows in the ¡¥format¡¦ box in the capture window.
5/ Information about your PC, amount of Ram, info on Cpu
(right click My Computer and select properties)
Please fill in the details on your forum profile.
Hope this helps
Hope this helps
