Upgraded to New Version: Import existing library Manager
sconto24
Post by sconto24 »
Sorry if this has been posted. I did a search, and found nothing. I recently upgraded to 11 from 9. I use library manager to categorize my clips. They did not carry over to 11. Is there any way to do this?
Welcome to the forums,
There is a way to do this, however you will loose any video clips in your VS11+ video library.
Not knowing what OS you're using here is the method in XP;
Navigate to C:\Documents and Settings\USERNAME HERE\Application Data\Ulead Systems\Ulead VideoStudio\9.0 and locate the file VS_video.dat. Select and copy that file.
Next navigate to the location of your VS11+ (the path should be the same as above, just replace 9.0 with 11.0). First rename the VS_video.dat file to something like VS_video.datX, then paste the one from your VS9 directory.
Now you will have all the libraries from your VS9 version..
The path to the files in Vista:
C:\Users\USERNAME HERE\AppData\Roaming\Ulead Systems\Ulead VideoStudio\9.0 or 11.0. (However I don't think you were running VS9 on a Vista machine)
sconto24
Post by sconto24 »
Thanks for the help, i believe im following your directions. Not sure why but im getting a "load from stream error"
i should add, raw data is located on an external hard drive. It is on and connected
Try copying a couple of the video clips from the external HDD to an internal one. Then relink when prompted to those, and see if you still get the error. This would either eliminate the HDD is causing the error, or reflect that it is.
sconto24
Post by sconto24 »
External was ok, tried it again, and it worked. You sir, are an awesome dude! thank you very much.
Thread re-titled and moved to FAQ's (Frequently Asked Questions)
