Devil wrote:The files should not have a .DV extension if they are proper DV files. DV files always have an avi extension. You can try changing the extension from DV to avi but this will not necessarily do the trick. However, it may be worth a try.
Hmmm - as far as I can tell they are definitely DV files. I did try changing the extension to .AVI but then got an error message "File reading error". I can watch them using Quicktime which happily recognises them as DV format files...
jparnold wrote:Where did you obtain the DV files? I have never heard of type DV files (eg filename.DV - I assume that this is what you mean).
There is a nice FREE utility which will display exactly what type of video file they are.
It is obtainable from
http://gspot.headbands.com/ and doesn't require installing.
If your video files are listed as type AVI I suggest that you rename them to filename.AVI
Thanks for the link. Yes, the files are named capturexxx.dv where xxx increases with each file. I have opened one of the files using the GSpot program that you suggest and it says:
GSpot wrote:File Type: Raw DV - IEC 61834 (.DV)
Mime Type: video/DV
Does that give any clue? - It says it is Raw DV so I would have thought that was ideal
The DV files were captured some time ago from a Panasonic NV-GS85. They were actually captured using a program called dvgrab on a Linux computer but I was confident that VideoStudio would let me edit them.
Edit:
Ken Berry wrote:Files with a .dv extension are the Apple/Mac version of our PC DV/AVi files. And while it is a nice thought, changing their extension to .avi does not work. The only way I have ever found to convert them is by using QuickTime Pro -- not the ordinary distribution version. It has to be the Pro version. I think I once suggested using SUPER but then I found I had deleted the few .dv files I had, and my one friend with a camera she uses on a Mac is currently overseas, no doubt making more files. So I have never been able to find out whether SUPER can do the conversion. I couldn't find any reference to .dv in the SUPER instructions, but then again, it doesn't mention DV/AVI either, nor other formats, so anything is possible...
Thanks Ken, it looks like you know the answer or at least the cause of hte problem. What a pain
I thought DV was a standard format
I will have to see if there is a way to convert them
