HAVING PROBLEMS WITH COOL 360 INSTALL AND RUNNING
I HAVE VISTA ULTIMATE AND R TRING TO INSTALL COOL360 AND HAVE COMPATIB. ISSES... HAVE DONE RECOMMENDED STEPS AND STILL PROGRAM ABORTS... CAN ANYBODY HELP ME?
Thomas Benigno
Welcome to the forums,
While I do have a hearing problem there is no need to SHOUT. Typing in CAPS is considered shouting in net etiquette, so please do not.
Cool 360 was developed way back for Windows 98 and NT4. Getting it to work with Vista will not be that easy. While you may get it to install, and work some of the times, do not be surprised or expect any fixes if along the line it fails.
In Vista you must run it under compatibility mode for either Win98se/ME or WinXP. Right-click on the Cool 360 desktop icon, and select Properties. In the properties dialog window, select the Compatibility tab. You'll see the Compatibility mode section at the top of the tab. In the section beneath that (Settings), select Disable Visual Themes, and Run this program as Administrator.
If the above does not work, then the only other recommendation is to setup a dual-boot system, running Vista and XP.
sorry for the caps... never realized it was on! nevr read before posting... that's why sooo mannny spelling errors. I will try your method and postt results. Thanks for your assistance.
Thomas Benigno
