Cannot start the capture graph.
MikeB51
- motherboard: Foxconn - A75M
- processor: AMD A4-3300 APU X2
- Video Card: ATI Radeon HD 4800 Series
- sound_card: High Definition Audio Device
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung SyncMaster 23 vis
Hi Team.
I'm suddenly getting the error "Cannot start the capture graph" as soon as I try to capture from my mini-dv camera. I've uninstalled and reinstalled UVS 11.5 but still getting the same message. Can anyone please offer advice. I don't even understand what the error means. :-)
MikeB51
rguthrie
- motherboard: MSI MAG B550 TOMAHAWK
- processor: AMD Ryzen 9 5900X 120-Core Processor
- ram: 64GB
- Video Card: AMD Radeon RX6600 XT
- Hard_Drive_Capacity: 2TB + 4TB
- Monitor/Display Make & Model: ViewSonic
MikeB51,
Not to be snobby but did you do a search for "Cannot start the capture graph"? Others have already posted the same question and perhaps the answer for you is already there. BTW, search for ALL keywords.
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
Canon Rebel T4i
MikeB51
rguthrie
- ram: 64GB
I know that sometimes getting the results from a search that you want can be frustrating at times! Who wants to read through 500 posts!
Canon Rebel T4i
Canon Rebel T4i
MikeB51
rguthrie
- ram: 64GB
Like I say, "It's just zeroes and ones!"
I wish I could help you better. I'm sure someone will help you get to the bottom of this. Good luck.
Canon Rebel T4i
Canon Rebel T4i
MikeB51
Have you tried capturing to DV format via firewire using Windows Movie Maker? If you have a problem there, then the problem is wider than Video Studio. It could be hardware -- though I note the playing about with the firewire card that you have done. Have you another firewire cable you can test it with? Have you a friend with firewire that you can test the camera with (as the camera firewire jack might be defective)?
Were you actually capturing from a mini DV tape or using the DV camera as a passthrough device? If the latter, check under ? > About Video Studio that your version number is 11.5.0157.2. If it does not end in 2, then you haven't applied the 6 November 2007 update patch which corrects capture via firewire with the DV camera being used as a passthrough device...
MikeB51
Well the only other thing I can think of is to go to the Microsoft DirectX website and install the March 2008 update patch for your DirectX. It is not included in automatic Windows updates, so you have to do it manually.
If that doesn't work, then at least you have a work-around with WinDV -- which I use anyway! (I admit, however, that I don't use it because I can't get VS11.5 to work!!!)
MikeB51
MikeB51
