Advance Button to work in Vista?
Barney1
- motherboard: Asus IPIBL-TX Burbank-GL8E
- processor: Core 2 Quad Q6600 2.4GHz 1066 MHz 8 MB L2
- ram: 4GB
- Video Card: GeForce 8400GS
- sound_card: Integrated 7.1 Sound
- Hard_Drive_Capacity: 200GB
- Monitor/Display Make & Model: HP w2207
Has anybody been able to make this work in Vista?
Barney1
- ram: 4GB
This link talkes about getting it to work in XP not Vista. Please see last three posts.sjj1805 wrote:try this link
Barney1
- ram: 4GB
Well I tried that directory and the button does not show up.
I also tried C:\ProgramFiles\Ulead Systems\Ulead Video Studio 11\Ulead.dat\.uvs.ini and that did not work. Finally I tried C:\ProgramData\Ulead Systems\Ulead Video Studio\11\uvs.ini and the button shows up. I made the changes suggested in the above link, but when I go to render I get a ¡§Failed to open the MPEG encoder¡¨ error.
Barney1
- ram: 4GB
- ram: 2 GB
- sound_card: Intel GMA 950
I got the advanced button to appear after changing the uvs.ini file in
I did not crash my system though when I did a test render.
I also changed the following
C:\Users\Stephen\AppData\Roaming\Ulead Systems\Ulead VideoStudio\11.0\uvs.ini
C:\Users\All Users\Ulead Systems\Ulead VideoStudio\11.0\uvs.ini (Had to alter the Windows security settings granting full control to "Users")
It was only after altering the C:\ProgramData\Ulead Systems\Ulead Video Studio\11\uvs.ini that the button appeared.
Barney1
- ram: 4GB
- ram: 2 GB
To change the Windows Security settings in Vista or XP (Pro only) you have to locate the file (or folder if you want to do a whole folder at a time) - using Windows Explorer. You then right click and select "Properties" and then select the "Security" tab.
I only had time to see if the advanced settings button appeared and just grabbed a sample clip and rendered it to make sure it didn't crash the system. Sorry but I am a bit busy at present with various household tasks and struggling to find time to do half the things I want to get done.
Barney1
- ram: 4GB
Well I got the security changed, but still getting the ¡§Failed to open the MPEG encoder¡¨ error. As soon as I change back the .ini file it works fine. Boy I wish I can get this thing to work!sjj1805 wrote:To change the Windows Security settings in Vista or XP (Pro only) you have to locate the file (or folder if you want to do a whole folder at a time) - using Windows Explorer. You then right click and select "Properties" and then select the "Security" tab.
