I just purchased the Canon HG-10 (very happy that it came boxed with Corel software!). I do not have HD equipment, yet, to play the AVCHD disks I can create, with the exception of using the WinDVD SE supplied with the camera. The raw footage, highest HXP quality, of this camcorder is incredible! The colors and resolution are beyond my expectations!
As I'm learning about this new camcorder, I simply make short, less than 5 min, test videos--no editing, just create a simple project and burn.
The AVCHD disk I made is also the same incredible quality as the raw footage. However, when I render the file and burn as a DVD, the finished quality of the video is quite pixelized, especially in the brighter areas of the video. (for example, my son was wearing a dark shirt with a bright yellow stripe. The stripe seems to sparkle in the DVD version of the video). I've tried several DVD formats and I have used both the Movie Factory 5.6 and the VS11.5 Plus. The last test I did, I used the VS MPEG Optimizer 16:9 HQ DVD with the same quality issues. I've also played the DVD in 3 different players---same results.
Although I am upgrading my memory to over 1.5G early next week (I only have 512 right now), could that be part of the problem?? Not enough memory to render it properly? Or is there some type of ACVHD conversion step I'm missing? Proxy Editing perhaps? (Been reading a lot about that here) I know I will experience some loss of quality going from the AVCHD to MPEG, but I'm pretty sure it shouldn't be so obvious!
Thank you. [/i]
