Video Studio 8 Show thumbnail number won't turn off.
pmwitt
Post by pmwitt »
Using Video studio 8 while on Create Disk Window, there is a check box for "show thumbnail number" for menu thumbnails. Although I do not check this box, there is nevertheless a thumbnail number next to each thumbnail. I have made hundreds of dvd's over a considerable period on different computers as my principle computer got replaced or updated. This problem did not exist at first, then came on intermittently. By now I cannot make any dvds without thumbnail numbers.
I capture s-video with an ATI Theater 550 Pro Pci Tuner and transfer these 2 Gb files over my local Gb network to my processing computer where I edit and compress the video as necessary. One recent project has from the project properties window;
File size 30 Kb
Version 8.0
Duration 1:04 (no compression needed here)
Edit file format MPEG files
NTSC drop frame 29.97 fps
MPEG files
24 bits 720x480 29.97 fps
Upper field first
(DVD-NTSC) 4:3
Video data rate 8000 Kbps variable
Audio data rate 384 Kbps
MPEG audio layer 2, 48 KHz Stereo
quality 100
* perform non square pixel rendering :?
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
pmwitt,
Look here C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead VideoStudio\8.0 for this file:
DVDMFEnc.ini
Open it and look for this line:
ShowThumbnailNumber=1
Change the 1 to a 0, so that you have
ShowThumbnailNumber=0
Save and open VS and test making a DVD and just go far enough to verify that this worked for you.
Also non-square pixel rendering is correct, because TVs use more of a rectangular pixel.
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
