Crash during import of an image
advad
Post by advad »
Hey everybody,
I have Ulead Studio 11 (german version - hope there is no difference :-) and it crashes during an import (loading it under the category images) of an image at the size of 10x10 (format bmp, gif or jpg) with just one color.
Importing an image with more than one colo is no problem.
I have tested it on serveral computers with different hardware (not older than 12 months).
The error file shows the following output.
--- SNIP ---
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="vstudio.exe" FILTER="GRABMI_FILTER_PRIVACY">
... a lot of <MATCHING_FILE NAME="...
</EXE>
<EXE NAME="Dir12.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="Dir12.dll" SIZE="26096" CHECKSUM="0x877DB1E2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x12078" LINKER_VERSION="0x0" LINK_DATE="03/01/2007 19:00:12" UPTO_LINK_DATE="03/01/2007 19:00:12" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="1058304" CHECKSUM="0xE7152EFA" BIN_FILE_VERSION="5.1.2600.3119" BIN_PRODUCT_VERSION="5.1.2600.3119" PRODUCT_VERSION="5.1.2600.3119" FILE_DESCRIPTION="Client-DLL für Windows NT-Basis-API" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Betriebssystem Microsoft® Windows®" FILE_VERSION="5.1.2600.3119 (xpsp_sp2_gdr.070416-1301)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. Alle Rechte vorbehalten." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x111ABF" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.3119" UPTO_BIN_PRODUCT_VERSION="5.1.2600.3119" LINK_DATE="04/16/2007 15:53:05" UPTO_LINK_DATE="04/16/2007 15:53:05" VER_LANGUAGE="Deutsch (Deutschland) [0x407]" />
</EXE>
</DATABASE>
--- EOF SNIP ---
Does anyone please have an idea or a solution
Thanks in advance
Achim
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
Achim,
Perhaps I'm confused, but why are you trying to import a picture with just one color? Why not just use Color located in the Gallery. You are not by any means restricted to using just those colors, you can use any color that you like. First drag a color to the timeline, then change the color of the clip on the timeline. This way you won't affect the colors already in the library. Once you have changed the color you can drag it from the timeline back to the library to reuse again in other projects or again in your current project.
Hope this helps,
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
advad
Post by advad »
You are right. If I just want to draw a uni colored box than I can use the colos. But I just played around with some different image pieces (of a complete image) and on of them was just with one color. So that was the reason why I came to this.
I wonder if I did something wrong or if this is a problem of the program. (Anyway I think it should not crash). I hope that adding an images (even it is just based on one color) does not have any affect to the colors within the gallery.
But thank you for the quick response.
rguthrie
ram: 64GB
Post by rguthrie »
Achim,
OK, so I was confused! :lol: I'd like to try to replicate what you did and see if I get the same problem. When you say 10x10, is that in pixels? Just asking because it could be that you mean something else like cm. Also, would you mind posting one of the pictures in your reply? That way I could use the same picture as you to test this problem.
Canon Rebel T4i
