Is there a way to have multiple transitions in a slide show? That is, can you have a wipe for some slides and a fade fo others in the same show.
Also the same question applies for slide duration. I have some slides such as maps that I would like to have displayed longer than others that are just pictures.
If you can't do this can someone suggest a workaround?
Slide show transitions for MF6
The easiest way is to break the slide show to sevral slide shows come one after the other. There is no problem to create slide show with only one picture.
In each slide show define the duration of each pic and the transitions effect.
[size=117][color=red][b]Read a little bit about me and my works at
[url=http://www.corech.com]http://www.corech.com[/url] [/b][/color][/size]
