NTSC to PAL
dbz2000
processor: InTel[R] Core [TM] i9 7900X 3.60 Ghz
ram: 16 GB
Video Card: GTX 1070
sound_card: NVIDIA High Definition Audio Device
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Dell ST 2310 Analog
Corel programs: VideoStudio 2018_ VideoStudio Paintshop
NTSC to PAL
Post by dbz2000 »
I am interested in converting a video I made in the NTSC format to PAL for a friend of mine in India. Is this possible or do I have to begin from scratch with the original files using the PAL format? When I think about it, it sounds like I will have to start from scratch. Any help would be welcome! :D
DBZ
"Instead of trying to add years to your life; try adding life to your years"
Devil
Post by Devil »
1. If the output is DVD (why didn't you tell us?) then just send him the NTSC one. PAL machines can read them.
2. If the input is DV (why didn't you tell us?), then take your final project DV AVI onto your timeline with your settings/properties set to the corresponding NTSC and make a new DV AVI.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
the to change from ntsc to pal is a very difficult process to do properly, you don't just have to change the fame rate and size, there is also the difference in chrominance/luminance/black burst/frequency, but VS will often do job good enough for friends to watch.
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
There is a tutorial on the subject at the link below that explains all the details however it is now a bit of a relic because most PAL DVD players will handle an NTSC DVD. In fact these days many NTSC DVD players will handle PAL.
As Devil pointed out we can only assume what you original format is and what your final format will be but the tutorial will give you the idea.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=11847
dbz2000
ram: 16 GB
Post by dbz2000 »
Thanks to all for your input. I failed to mention that my original was in DVD format :oops:. My bad!!! I too assumed that PAL machines would read it; however, my friend says she has tried to use NTSC in her machines before and they wouldn't or didn't play. It must be an older model. Nonetheless, I will attempt to make it over from scratch to avoid any possible compatibility problems. I was hoping for a shortcut somewhere in all of this.
I will check out the link suggested and see what I can come up with. It is her son's graduation and she won't be coming to the USA anytime soon. Thanks again to all. I always get great direction from this forum. :D
Peace.
DBZ
Post by Trevor Andrew »
Hi dbz2000
I had to change some menu/settings on a machine before it would read Ntsc version DVD¡¦s.
Cant remember exactly which settings (quasar rings bells) the player is no longer so I cannot check
May be worth looking through the players setup.
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
The tv also needs to be compatible with the signal.
dbz2000
ram: 16 GB
Post by dbz2000 »
Thanks to all! I will check some settings to see what I can come up with. In the meantime, I will begin working on doing thje project over with the PAL format. I appreciate everyones input and suggestions. Take care.
DBZ :)
Hi DBZ
Try rendering the completed Ntsc video to Pal.
First use Make Movie Manager-Add function to create a template of the Ntsc video.
Edit the template changing the :-
Compression to Pal-DVD
the Audio to Digital Dolby
Save the template.
With the Ntcs video in the timeline Share-Create Video File ¡V select your template.
dbz2000
ram: 16 GB
Post by dbz2000 »
Thanks Trevor. I will give it a try and see what happens. I mean what's the worst that could happen other than having to do it from scratch. Man you guys are really cool to continue to offer assistance with projects. Corel should hire some of you guys as online tech specialists for their products. I mean, your advice has always been superior to what I usually get when I contact them. :D Thanks again.
DBZ
