I am having problems with subtitles importing VOB files directly from orignal dvds. In the "info" window (just before I import a file), i can read there is the subtitles but after I have imported it, the subs are "off" and no way to import them (the only things i can do is to "work" on the VOB file and save the subs in a .srt file).
Another problem that is occurring right now is with audio, with one specific file though. In the import window, i read there is the audio stream (and if I check the video I can hear it), but after I've imported it, the properties of the video says "no audio". This is strange, isnt it?
Is there anyone who can help me?. Thanks. Alessandro.
Problems with audio and subtitles importing VOB files
I believe it's normal to loose subtitles when you import.
Importing DVDs can be "difficult". If all of your DVDs come from the same DVD-recorder, or from the same DVD-camera, you can usually find a procedure that works consistently. But, if you are importing DVDs from several different sources, it will sometimes be a challenge.
Is there anything different (compared to the "good" DVDs) with the audio format on the DVD that won't import?
You may need to look for a different "DVD ripping" program. VOB 2 MPG is FREE, so it's probably worth a try.
And, you can find programs to "rip" DVD audio. If you can get the audio into a WAV file, you can use that separate audio file with Movie Factory.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
