Runtime Errors
shiftyryan
Runtime Errors
I got Ulead PE 8.5 with my new Speed camcorder, and was happy with its function, except that it would automatically keep my photos in a file (Ulead.dat) that my media centre didn't look in. I now have a much bigger problem though... I was moving some baby photos into a new empty folder under the Ulead tree so they could be saved for printing. I think all I did was create a new folder in the section where Ulead automatically stores the photos. Next time I tried to open Ulead it could not open properly and gave this message: Microsoft visual basic C++ runtime library - runtime error! - program:...ulead systems\ulead photo explorer 8.5SEBasic\Pex.exe - abnormal program termination. This message was displayed in a error box and the only option is to click the OK botton and then Ulead closes. Furthermore, I got worried about the photos and went searching through my computer and looked in the Ulead trees and could not find any trace of them. I have no idea what happened, and I don't know how to fix the problem. I thought about re-installing the software, but I am worried that the photos might get lost. So that is my actual question - could the photos be somehow lost & should I re-install using the disc?
John Moran_2
Runtime error starting PEX
My solution:
I found another solution(workaround) instead of reinstalling the program:
1. Try to remember wich devices you used in de Photo explorer (USB-stick, external drive, DVD- CD-drive, or photo-camera connected by USB;
2. You can only start PEX(Photo Explorer) with a volume loaded in this devices!
3. if you don¡¦t remember wich devices you used before, plug in a volume in every device your system has.
4. Start PEX. On my system it is then starting without error!
5. If PEX is normaly started: goto File/Preferences/ (or F6 key), take category Cache and under ¡§History¡¨ clean all adresses and maps by clicking the button.
6. Close PEX. Remove all the volume¡¦s you don¡¦t need;
7. Restart PEX. Now the program will start without any error.
8. Advice: each time you use PEX with an external device do action 5. before closing the program.
