I'm using Ulead VS 11.5 Plus.
The Ulead UVS11 Preload (uvpl.exe) program starts every time I start up my computer and I have come to the conclusion that it is slowing the log on time quite a bit.
Is it necessary to run this program or if I disable it, will it just be a simple case of waiting a little longer when I run the VS program for the first time (which is preferable)
I'm going to try it a see later and see what effect it has, just wondered if anyone knew/had tried it before I did, in case it causes problems and I end up having to reinstall the program.
elyoh
uvpl.exe at Logon
My that was a fast reply. Thanks, that's helpful.
I found this application from Microsoft:
http://technet.microsoft.com/en-us/sysi ... 63902.aspx
It allows you to turn off certain entries from running at startup and turn them on again if need be.
I'll let u know if it makes any difference to log on speed.
