Enlarging a cropped video clip to fill the screen
Berzelius
- Hard_Drive_Capacity: 2TB
- Corel programs: VS X10 Ultimate; VS X7 Pro; VS 11Plus
Say you have a storyline consisting of 3 mpg video clips. If you crop the centre clip and create a video file of the storyline then, if you play the file, you start off full screen, then get a jarring jump to the picture showing the black "cropping" border and then another jarring jump back to full screen. Is there any way of making the cropped clip appear full screen in the final video file?
I have VideoStudio 11 running under Windows XP/HE/SP2.
The only way that I can find to do this, is using the overlay track.
With your clip in the overlay track, do not use the Overlay Filter. Instead select Apply Overlay Options. Then select Chroma-Key. Now below this are 3 options, Similarity, Width and Height.
Using the width and height, you can crop your video to the desired area. Once this is done, resize your video, by dragging the yellow corner handles in the preview window, continuing until you have the video filling the screen, and the black areas are well outside the Title Safe boarders. You may need to move the clip around in the preview window to be able to resize it fully.
Also be sure to set the Similarity to black and zero.
rguthrie
- motherboard: MSI MAG B550 TOMAHAWK
- processor: AMD Ryzen 9 5900X 120-Core Processor
- ram: 64GB
- Video Card: AMD Radeon RX6600 XT
- Hard_Drive_Capacity: 2TB + 4TB
- Monitor/Display Make & Model: ViewSonic
Berzelius
Many thanks for the info - the filter does the job required. However, one unusual thing. In Help, under Pan & Zoom, it starts off by saying: Pan & Zoom is applied to still images and yet it seems to work with video clips.rguthrie wrote:Berzelius,
Just use the Video Pan and Zoom filter on the middle clip on the Video Track and you'll get the same effect.
Ronald Guthrie
rguthrie
- ram: 64GB
You are talking about 2 different things. Pan & Zoom is for stills, Video Pan & Zoom is for video.
Jeff
Dentler's Dog Training, LLC
rguthrie
- ram: 64GB
Yes, that is what I meant.
Jeff
