Slow Burn with Trial V S Plus
Ken - I'm sorry to ask, but I seem to have the same problem as before,
except with a short (6 min) video. I put together a series of photo images in the Movie Wizard, adding a music track, then went into the full UVS screen and set up the titles and transition effex. I followed your previous advice, Create video file> DVD/VCD/SVCD/MPEG>NTSC DVD 16:9 (or should I have gone create video file > NTSC DVD (16:9, Dolby digital 5.1?). Anyway, the rendering process looks slow again. I estimate it would take almost 90 minutes for a 6 minute video. It has about 50 pictures, with a crossfade or fade-to-black transition between each. Any advice?
With your system, it should not take that long to render a 6 min project, especially a slideshow video.
Do you shutdown all, or any background applications while rendering? I've had an occasion where my anti-virus started scanning in the middle of a test render. Normally I use my Video Editing Profile, where everything not needed is disabled. This really slowed down the process.
Right-click on the bottom frame of your window, and select Task Manager, select the Processes tab. How many processes are running when you prepare to render?
72 processes?
I have 2 hardware profiles on my system, Normal which generally has 44 processes. Under this profile of course I have my anti-virus, spyware checkers, internet, basically everything.
I also have a special video editing profile, which only has about 25 processes running (I don't disable my Wacom tablet), however I have had it down to about 18 processes. This is so the PC can devote most of it's time and energy to editing/rendering my videos.
There's various means to cut down on the processes, one being creating a separate "video editing" hardware profile. You might want to review Steve's tutorial on Creating a Video Editing Profile.
You can also search for some utilities like EnditAll that allows you to stop un-necessary processes, freeing up more for your editing.
I think that having so many processes running while trying to render is a major factory in the slowness you're experiencing.
- ram: 2 GB
- sound_card: Intel GMA 950
14 min for a 6.5 minute video is probably about right.
Often these take between 1 and a half to 3 times the amount of time of the actual video. It will vary according to the amount of work involved.
A piece of unchanged video will render very quickly, but another with transitions, titles, altered soundtracks and multiple video tracks will take a lot longer.
Ken/Vidoman/sjj1805 - i have decided to give VS a try, so I'm going to purchase the program. can you guys recommend a reasonably priced capture card i can use to capture video? i have an older Hi-8 camera with s-video and composite outputs. i also have an inexpensive, entry-level mini-dvd camera with a composite only output.
