Sent: 20 April 2008 08:59
To: sjj1805@
Subject: Convert to DVD
I hope you are well and once again I need to ask your advise. I am not sure what to do with regards to the forum as the question I have relates to the above software. Your advise please then I can use the forum. This package seems to work, I have tried other options and this seems the best so thanks for your guidance, it also loads in VS for editing, great news. My problem is that I film in short bursts so anything from 15 sec of footage or longer this means that a 5 min film on MPEG4 can create 15 clips. Is there a way that these can be joined together before they are converted or do I have to convert 1 by 1. Or is there another tool to do that! I know that the DVD movie maker allows you to join clips but it does not allow editing and the results are poor.
Thanks Again.
Paul
Paul and Jane Willcox
Southbank
Reply
Without doing any editing and if all the clips are the same format then VideoStudio will quickly create a new file of that same format.
Place all of your clips on the time line and then go to the share tab and select create video file, select ¡§same as first clip.¡¨
Regards
Steve Jones
Administrator Corel User to User Web Board
Convert MPEG4 to DVD
