jerky motion in burned dvd
A film I've transferred through Movie Factory 4.0 looks fine in U Lead but the burned DVD looks pixilated and the motion is jerky
The file is 80 minutes, 1.4 GB
I'm burning it onto a standard 4.7 GB disk in an external DVD burner
These are the Project Settings:
MPEG files
24 Bits, 720 x 480, 29.97 fps
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 256 kbps
Do not convert MPEG files and Treat MPEG audio as non-DVD compliant are checked
The output is NTSC.
MPEG files
(DVD-NTSC), 4:3
The output is NTSC.
Your project settings look fine...
Format conversion is generally "difficult". You might want to try converting your file to MPEG-2 with SUPER (FREE!!!). Use the same (or similar) settings as you used for your Project Settings.
You will always get some quality loss when converting from one lossy format to another lossy format. The amount of (additional) quality loss depends on many factors. Conversion can be especially difficult if you need to change the framerate and/or the resolution.
What is the format (and properties) of the original file? (This is probably not DVD-compliant MPEG-2.) Where did this file come from? (If it's possible for you to re-capture to a less-compressed format, that will probably help.)The file is 80 minutes, 1.4 GB
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Film makes it very tricky... Somebody else will have to help you with this. I've never done any film transfers or framerate conversions.
The film framerate will NOT match the 29.97 frames-per-second required for NTSC. I think 16mm is 24 frames-per-second (same as professional 32mm or 64mm).
The pros do the framerate conversion with "2:3 pulldown" as part of the telecine process
You still didn't tell us the properties of your 1.4GB captured file. It's much more compressed than your project settings. ...You can't get "DVD quality" from an 80-minute 1.4GB file. You will get better results if you set-up the Belkin software to capture in a format similar to your (DVD-compatible) project settings.
No time to think.
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Are the framerate and the 2:3 pulldown things I can set IN U Lead? I read the Wikipedia entry and it seems film and PAL have similar frame rates. I tried setting source to PAL in U Lead but that wasn't it. The picture in U Lead after I capture looks good. The problem only appears in the burned product.
I don't know what you mean by this.
There is no software. It's just a non-powered plug with video and audio outputs.
Thanks for your help.
After you capture the clips with your Belkin adapter, right click on one of the clips in the library. That will give you the clip's properties.
Besides the frame rate, make sure the field order is the same throughout. Since you captured analog video the field order is probably Upper Field First. Make sure your project properties and burn properties are also Upper Field First.
Jeff
Dentler's Dog Training, LLC
I see!
File Format: MPEG 2
File size: 1,236,739 KB
Duration: 4944.344 seconds
Video type MPEG-2, Upper field first
Total frames: 148,182
Attributes: 24 bits, 320x240, 4:3
Frame rate: 29,970 Frames/sec
Data rate 1800 KBS
Audio type: MPEG Audio Layer 2 files
Total samples: 210,045,486 samples
Attributes: 44100 Hz, 16 bit stereo
Layer: 2
Bit rate: 224 kbps
File Format: MPEG 2
Data rate 1800 KBS
Layer: 2
Bit rate: 224 kbps
I tried burning at a slower speed as recommended by Corel to avoid jerky motion. The motion is better but not perfect and the picture quality suffers.
Why am I creating inadequate sized files for DVD quality? Is it the method of capture (a Belkin USB adapter). If so, the captures look perfect in ULead while I'm adding menus, mutitrimming, etc. but not good once burned.
Thanks.
Thanks.
- ram: 2 GB
- sound_card: Intel GMA 950
The jerky motion may be as a result of the fact that the film frame rate is 24fps and you are converting it to NTSC at 29.98 fps so it has to invent some extra frames probably by duplicating them.
The other normal cause of jerkiness is incorrect field order. Your input properties posted above show Upper Field First, double check that the output is also Upper Field First. You cannot rely on the "Do not convert compliant MPEG files" because the chances are yours are not compliant and being converted to the project settings. In your initial post you missed out what field order was set.
