Hello
I was using XP with studio 9. Upgraded to vista and am trying out the trial version of studio 11 ( also had to buy new tuner to work with vista)
Windows media center puts a show in the "public / recorded tv" file and labels it " microsoft recorded tv show". When I load it into video studio, it converts it to a "dvr - ms" file - this converting process takes 4 or 5 minutes. Then I drop it into the story board or time line and it only shows 30 seconds. I do a properties on the dvr - ms file and confirm that it is 60 minutes.
Obviously I have done something wrong or there is a fix or update - sure would appreciate some guidance
Thanks, Doug Fraser
Ps vista is sure a pain
Studio 11 1 hour clip shows 30 seconds
Doug Fraser
rguthrie
- motherboard: MSI MAG B550 TOMAHAWK
- processor: AMD Ryzen 9 5900X 120-Core Processor
- ram: 64GB
- Video Card: AMD Radeon RX6600 XT
- Hard_Drive_Capacity: 2TB + 4TB
- Monitor/Display Make & Model: ViewSonic
Doug,
I know you're pain. On my XP system, I can get as far as about 5-6 minutes into a show. I brought up the idea a few years back about VS having native support for dvr-ms. Well, I'm sad to say that it was not implemented that great in version 10, and it's much worse in 11.
You're best bet is use another program to encode your dvr-ms to another format (which will basically just strip the ASF wrapper from around the MPEG video). BTW, the ASF wrapper contains information about the show the MCE uses.
In short, Google "dvr-ms to mpeg" and you'll stop banging your head on the wall. Two notible programs are dvrmstompeg (short and quick to the point) and DVRMSToolbox (which has more encoding options, such as encoding to WMV as well as MPEG). Then just bring your mpeg file into VS and you'll be much happier.
Hope this helps,
Ron G.
Hope this helps,
Ron G.
It's probably not you. It's probably the video file... There are just too many audio/video file formats and too many variations of each format. (And, I don't think Corel tries very hard to support the variations.)Obviously I have done something wrong...
Strange... What format is it before you load it?When I load it into video studio, it converts it to a "dvr - ms" file...
You can try using a 3rd-party program such as SUPER (FREE!!!) to convert the file to another format before loading it into Video Studio. (i.e. If you are making a DVD, convert the file to MPEG-2.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Doug Fraser
Thank you to rguthrie and DVDDOUG for their guidance. I understand my problem is not unique but following the advice of these 2 guys, I checked out a number of dvr-ms to mpeg utilities or programs. I found one that is so simple and straight forward even I can understand. I recommend checking out the following:
http://dvrmstompeg.googlepages.com/dvr- ... gconverter
Thank you very much, Doug
rguthrie
- ram: 64GB
