2.Please devide into 3 parts, now click Web\Grid and Partition, then setup it as below, please remember to check the item "Convert cells to objects"
3.Now click Show layer manager, you will see there are 3 objects. Please click object-1, then click "create a layer mask". Please also do that for object-2 and object-3.
4.Now select the object-1, then right click your mouse, select "Properties", it will pop up a new window, please check the item "Placeholder". (Attention: if you can't check this item, it means you have to convert the object into image firstly.) Please also do that for object-2 and object-3
5.Now click Share\Photo Projects, it will open a new window, click Browse and then drag the photo to the template.
6.Click OK and save it as UFP file for further using.
[/img]
