combining projects
pboss
combining projects
Post by pboss »
I think I know the answer to this one, but here goes...I have 2 projects that turned out to be about an hour long after much editing. The easiest thing to do would be to combine them...somehow, but I don't see how that is possible. Is it? or...what would be a way to hold onto the edits - I am thinking of turning into a video and importing that.
thx
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
If you are done editing then by all means create a video file then combine the two video's together in a new project.
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
pboss,
I'm assuming that you have actually saved two projects and would like to combine them easily. The answer is yes you can with my following powertip (which is also a shortcut to waiting for two videos to render and then waiting for your final video to render). I call it a powertip because it can be used creatively in many different ways (hint: think text, e.g. "Star Wars" effect). Anyway here's Ron's Powertip:
Open VideoStudio.
Select File -> Insert Media File to Timeline -> Insert Video; Select your VSP file for the video you want first. Repeat for next project file, render and you're done!
Hope this helps,
Ron
bob733
Post by bob733 »
And to add on to this.I made a final vsp that actually 9 other vsp files in it.What is nice is that you can go into any of the vsp files, edit them and then bring it back into the main vsp file.
You can create effective transitions by putting the vsp files on different time lines.it worked great.
Here is what did not work and I hope not to make it too complicated.
You can only go 1 LEVEL DEEP in bringing in vsp files>
For example.
In MAINVSP (you inserted SUBVSP1, SUBVSP2 ...SUBVSP9 etc ) is ok.
As long as SUBVSP1 AND SUBVSP2 themselves did not have another vsp file inserted in them. You can insert anything else in the SUBVSP files (mpg, jpg, sound etc) but not another VSP file.
Hope I did not muddy the waters.
But for editing, I would go into the second vsp file. Edit the hell out of it.... create chunks of it into other vsp files. And then, go back to the first one and start inserting the vsp chunks you created from the second one... Put the chunk vsp files where ever you want on the main vsp time limes (1 through 6) and that will work.
Hope this helps.
Bob
That's very interesting and helpful Bob..:) I'm curious could you elaborate on what type of source files were in your 'nested' VSP files, and if you noticed any loss in quality?
Blacklab has posted that in trying this method, he had some loss in quality. I would think that in using DV files as the source in all VSP files there should not be any quality loss.
bob733
Post by bob733 »
Hi Ron
The source files for the SUBVSP files were everything. MPG. PNG JPG. Blufftitler, Audio etc. I saw no loss of quality.
In fact, the VEOH I sent you for a private viewing the other day, was the MAINVSP file that had the 9 SUBVSP files in it. And as I mentioned, the only problem was with the Internet streaming of the MPG files but on the final rendered Physical DVD disk, it was perfect.
Hope this helps,
Bob
rguthrie
ram: 64GB
Post by rguthrie »
Bob,
I can't believe you let the cat out of the bag! :D
Now folks will know that they CAN have transitions in their overlay tracks (without waiting for VS12). This is another use of my powertip that I've been using for a while (I think since VS9..at least that's when I discovered it).
Ron G.
tommytucker
Still a bit confused. Is bringing in a VSP file in the Share
Post by tommytucker »
stage the same as what you are saying with:
Open VideoStudio.
Hope this helps,
Ron
I have also heard that one should render to an AVI file then bring those projects into the timeline, not VSP. Can you help me understand this thread a bit better?
pboss
thx!
Post by pboss »
wow - too many smart people out there...now I have to figure out which ONE to do! Great forum - thx for allllll the help.
Re: thx!
pboss wrote:wow - too many smart people out there...now I have to figure out which ONE to do! Great forum - thx for allllll the help.
Do them all..:) :) , just not at the same time..;)
bob733
Post by bob733 »
In the subvsp files, I brought everything in (AVI, MPG, Audio, PNG, JPG....I mean everything). I would not render the subvsp files. I just went to the MainVsp files and inserted them into the necessary timeline.
That way, it was much easier (and quicker to render.... as I was not rendering each subvsp file). And, by not rendering them, I could go into the subvsp files and swap out pictures, change audio... what ever I wanted to do)
When I was ready to wrap it all up... I would just render the MainVsp file.
Done.
Easy.
Efficient.
And because you have entered the world of Modular Programming, it is much much much easier to modify, add or delete to your hearts content.
Bob
laurentje
motherboard: Dell XPS 8920
processor: Intel i7-7700 3.60 GHz
ram: 16 GB
Video Card: Nvidia GeForce GTX 1060 6GB
sound_card: Realtek
Hard_Drive_Capacity: 2T + 250MB
Monitor/Display Make & Model: Samsung S24B350
Corel programs: VideoStudio X10
Post by laurentje »
bob733 wrote:In the subvsp files, I brought everything in (AVI, MPG, Audio, PNG, JPG....I mean everything). I would not render the subvsp files. I just went to the MainVsp files and inserted them into the necessary timeline.
Bob
What are the project settings in the subvsp and in the Mainvsp? Frame-based or interleaed. Can they be different?
