Help/suggestions with bitrate.
1Click is capable of doing all sorts of bitrate changes. What happens if you burn directly from VS?
For the videos I shoot with my Canon S3 IS camera (640x480 30hz AVI) I wanted a decent compression while retaining the best image quality.
MSU is a nice tool to help you do this. First generate an output file using a certain mpeg profile (bitrate, gopp, vbr, 1pass/2pass etc) then compare this file with the original (avi) file.
MSU gives an overall image quality figure as a percentage of the original movie. I got the following results: figures: (vbr, size + percentage wrt org file, quality = SSIM_YYUV %)
MSU produces a nice output movie of the differences between the original file and the test file - at low bandwidths it shows that a lot of detail is lost, while at high bandwidths the screen is mainly black, showing that there is a close match between the original and the test file.
ORG AVI: 17976 kb
_4M______ 4791 27% __ AVG: 0.9215
_6M______ 7341 41% __ AVG: 0.9578
_8M______ 9419 52% __ AVG: 0.96499
_8M__2P__10189 57% __ AVG: 0,97134
_9M__1P__10577 59% __ AVG: 0,96952
_9M__2P__11431 64% __ AVG: 0,97512
_8.6M_2P__11000 61% __ AVG: 0,9735
10M__1P__11737 65% __ AVG: 0.9736
_9.5M_2P__12100 67% __ AVG: 0,9765
10M__2P__12699 71% __ AVG: 0,9780
12M______15217 85% __ AVG: 0.9824
From the results it follows that 8M, 2pass gives better results then 9M 1pass - in fact, 8.6M 2pass is as good as 10M 1pass.
Also, the quality improvement using higher bandwidths then 8M2p is minimal, only 0.66% to 10M2p but the resulting file is 25% larger!
I now generally use the 8M2p setting, while using 12M2p for valuable footage where quality is more important then file size.
ORG AVI: 17976 kb
Barney1
- motherboard: Asus IPIBL-TX Burbank-GL8E
- processor: Core 2 Quad Q6600 2.4GHz 1066 MHz 8 MB L2
- ram: 4GB
- Video Card: GeForce 8400GS
- sound_card: Integrated 7.1 Sound
- Hard_Drive_Capacity: 200GB
- Monitor/Display Make & Model: HP w2207
Barney1
- ram: 4GB
1-click is not a burning app as such, it is a DVD-copy application and it will adapt bitrates for fitting. You should use the DVD burning bit of VS: you can do that at the same time as you create the DVD files. You can be sure that way that it is burning what you create and not what a third party software THINKS you ought to do.Barney1 wrote:I will take a look tonight to see where I set that in 1Click. I don't recall seeing that anywhere. Thanks!Devil wrote:1Click is capable of doing all sorts of bitrate changes. What happens if you burn directly from VS?
Barney1
- ram: 4GB
Well a fixed bitrate of 7000 and 8000, the video quality drops.
Devil,
I understand what your saying and I agree. I only use 1Click to copy the files that VS create during rendering. I can try to just burn to disc, but could you imagine the wasted disc I would have had. What I can¡¦t understand is if you set a variable bitrate with a max of 7000 how does the video get create with spikes well over that if you are telling it not to go over 7000? I see this when I create the DVD folder and play the video from WinDVD9. Thanks.
Devil,
Haven't you heard of DVD¡ÓRW discs? You wouldn't waste any with them, until you got your project right.
Barney1
- ram: 4GB
Barney1
- ram: 4GB
YES I have heard of DVD¡ÓRW disc. That is why I¡¦m writing to a DVD folder and then viewing it from WINDVD9.Devil wrote:Haven't you heard of DVD¡ÓRW discs? You wouldn't waste any with them, until you got your project right.
Well I have finally gotten it to work without any freezing, by not checking the ¡§Two Pass¡¨ function when creating the DVD and/or DVD folder. Doesn¡¦t make sense, but I¡¦m all out of options and patients as far as this project goes. There is some quality difference, but not that noticeable on lets say a 32¡¨ TV which is what most if not all the people I¡¦m making this video for have. As far as my viewing options, I can bump the bitrate to 9696 @100% with two-pass checked and it plays fine and looks pretty good on my 65¡¨ HDTV using PS3 as the player with no problems. If I can get the PS3 to recognize .avi files that would even be better.
[quote="Barney1"][quote="Fransl3"]
[/quote]
Fransl3, What is MSU and how can I get it? Thanks.[/quote]
Barney,
1st sorry for a late response, I dont check this account very often...
MSU Video Quality Measurement Tool can be found at:
http://***/video/quality_mea ... ol_en.html
Usage is pretty straightforward, only thing is that for MPEG2 you need AviSynth - create a .avs file containing a line as follows:
DirectShowSource("c:\<path>\<moviename.mpg>", fps=<framerate>)
The MSU output clip clearly shows the distortion; the following 2 images show the rather significant distortion for a 6Mb 1pass clip, compared with a 8Mb 2pass clip.
Hmm... can't attache the images... too bad...
Rg,
Frans
[img][/img][img][/img]
[/quote]
Barney,
Rg,
Frans
