Can someone reproduce this problem in VS8?
Keith C
Post by Keith C »
Hi, I'm using VS8 with the Burger transitions.
I drag two - 5 second jpgs to the storyboard and then insert the "Chars" Burger transition between the 2 jpg clips. There are no other clips on the story board. Immediately VS8 freezes and looking at the task manager I have this: vstudio.exe - cpu usage 99 - mem usage 49312k. Also in the Local settings/temp folder I find the following "Security Catalog Files" have appeared:
~~Frame.CAT - 102,400 KB
~~THUMB.CAT - 5120 KB
~~VTHUMB.CAT - 5120 KB
This problem does not happen with any other Burger transitions and I particularly wanted to use this one for a project.
I have to shutdown VS8 in the task manager and then I can restart the program - I don't have to reboot the computer.
Could some kind person try and replicate this situation to see if it is just my problem or one that is caused by a faulty vfx file.
Many thanks
Post by Trevor Andrew »
Hi Keith
You are correct the transition 'Chars' think its numbered 12 does indeed freeze video studio.
Delete the corrupt file burger12.vfx
I also saw a note from some other user on the burger forum/site complaining about this.
All the others are good.
Keith C
Post by Keith C »
Thanks for that Trevor.
I have deleted no. 12. Glad it was not just me. BTW do these Burger transitions work OK in VS9?
MikeGunter
Post by MikeGunter »
Keith C wrote:Thanks for that Trevor.
Mine seem to.
I haven't run the list.
Mike
I do not have VS 9,
Awaiting the trial before upgrading
I see no reason why they should not work.
