So - got home, uninstalled failed installation and cleaned leftovers.
Installed VCredist V2005 x64 from Microsoft downloads - installed WinDVD9 and it worked. Seems like on 64-bit machines you need to insatll manually te 64-bit redits package for VC++.
Hope that will help others too!
Michael
Error 1904 in Installing WinDVD 9 on my Vista Ultimate Edit
Moderator: lata
aquario1972
Help
I've the same error 1904 problem and can´t find a solution for that. I've Windows XP Professional, Service Pack 2 and that ivivideo.ax is annoying
Thank's
Sérgio
Thank's
Sérgio
SOLVED
I had this same problem (both on install and uninstall) on Vista Ultimate 32bit following a reinstallation.
I tried to use the Radlight Filter Manager to manually install the codec, which told me I was missing/had not registered D3D9_29.dll, so I downloaded that from Gamers Nation and installed that update.
After that, I was able to manually register ivivideo.ax - and now WinDVD9 installs and runs properly.
Hope this helps someone else!!!
