Error 1904 in Installing WinDVD 9 on my Vista Ultimate Edit
Moderator: lata
i am getting that errror 1904 while installing windvd 9 on vista ultimate i tried more than 10 times reinstalling but no use
Thank you sir i try and i get the following eror:
The module ":\program files\intervideo\common\bin\IVIVIDEO.AX" failed to load.
Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent.DLL files.
The specified module could not be found.
windvd is installed i try to reinstall again still give me the same error.
I don't see how this link helps ??
I have an OEM version of VinDVD 5 running perfectly and I wanted to upgrade to version 9 and this does not work because IVIVIDEO.AX could not be loaded !!
I exchanged a lot of messages with the Corel Support BUT they could NOT solve the problem !!
Thank you in advance for your reply.
Best regards, Jean-Claude.
Jean-Claude
MHochegger
oddius2008
MHochegger
Same thing again!
Uninstalled everything and checked Registry and file system - rebooted - deleted all files in Temp - rebooted - started install with admin-privilieges - same error again.
Tried to register the ivivideo.ax and got mentioned message about a missing module.
Untill WinDVD 8 I never had any issues with Intervideo products - now that Corel owns the product issues arise....
Michael
Michael
MHochegger
MHochegger
