Could someone help me with the following issues with VS 11+:
1) How do you achieve a slow fade to black? The longest duration it will allow me to input is 00:00:00:29. Not slow at all. I've tried multiple combinations of transitions using a black color block, overlay track, etc. But I can't find a workaround for this. Surely there must be a way to achieve a very gradual fade to black in between clips?
2) I couldn't find a transition that was a fade-up from black. Is there one?
3) How do you recover library clips that were accidentally deleted? I looked in my computer's recycle bin, but they weren't there, and I can't find a recover or undelete function in VS.
4) I cannot get the trim handles to work, when trying to trim a clip. I follow the instructions, putting my mouse over a handle, left-clicking, and holding it down while I press the left or right arrow key, but every time, it slips badly. The only time it works (sometimes) is if I'm in audio view. But in timeline view and storyboard view, the trim handles won't maintain the right time code, and slip all over the place. Do I need to be using a special mouse, or could this be a defect of the software? It's really hampering my ability to edit, because I often edit frame by frame. I know I can go in the multi-frame view, but when I do that, the ripple editing gets thrown off.
5) Which leads me to my next question. Why on earth doesn't ripple editing work if you're rearranging clips on the timeline? It works only when you're dragging and dropping from the library. But when I want to juxtapose clips that are already on the timeline, or if I want to trim a clip in the multi-frame view, it doesn't work. VERY FRUSTRATING.
6) No transitions allowed on the overlay tracks....big oversight.
7) I wish it had more audio tools and filters, like being able to remove a hum or other background noise that is at a constant frequency. I have found the audio filters to be not very useful. For example, I had a short applause clip that I needed to elongate. I tried copying and pasting the clip and putting them side by side on the audio track. Then, I wanted to even out the applause across all the tracks. I tried 2 different filters, but they didn't work.
9) Why is there a pop or a hiccup when going from audio on an overlay track to audio on the primary track? It's not smooth, and you can tell when listening that an edit was made. Is there any way to get rid of it?
10) WE NEED TRANSITIONS ON THE AUDIO TRACK (in case anyone from Corel is reading this). I want to be able to crossfade audio without crossfading the video. Is there any way to do this?
There's more, but I'll save them for later. I would appreciate any advice you experts can offer. Thanks.
