When I try to create a disc, I get an error after pressing the next button on the preview menu. It says, "Program Files\Common Files\Ulead System\DVD\uDVDBurnmgr is not registered!" I press OK and try to output the project, but MF freezes.
I run a Windows XP SP 2 with 1 GB of RAM. How can I fix this error? Thanks.
MF 3.5 error
You can try to manually register that DLL file by doing the following:
- Open a command prompt window, by going to Start>Run, and typing in cmd, then press Enter.
- Using the uDVDBurnMgr.dll and path "C:\Program Files\Common Files\Ulead Systems\DVD\uDVDBurnMgr.dll", call regsvr32, ie; type the following at the command prompt:
- regsvr32 "C:\Program Files\Common Files\Ulead Systems\DVD\uDVDBurnMgr.dll"
- Press Enter
- You should see a regsvr32 window confirming success. Close it.
iloweredmycarbs
iloweredmycarbs
