I don't know if you've managed to correct this, however following the directions set out in This Thread, and just using the following path for Vista should correct it.burrwick wrote: know there is a separate thread concerning restoring the video filters when they "disappear" but that thread seems to cover the fix for Windows XP.
I have the same problem but in Vista. Folders mentioned in the other thread aren't the same in Vista. I can't even find the uvs.ini file in Vista which is the file that other users suggest needs to be deleted to restore the video filter options.
Anyone have this problem in Vista and have a fix?
Thanks for any help!
C:\Users\UserNamehere\AppData\Roaming\Ulead Systems\Ulead VideoStudio\11.0
