Capture Problem
Indyana
Capture Problem
Post by Indyana »
When i'm doing capture of my VHS (using Pinacle Video Lynx), all is working fine, preview is ok, sound is ok, etc... But when i read the AVI file generated, the movie is played too fast (arround speed x3) and with no sound. The capture frame rate is set to 30 frames/s and when i read video properties details i see 91/frames/sec.... Well, i don't realy see where is the problem... This problem occur with all output format.
Could someone help me please?
Welcome to the forums,
We are going to need some more information in order to help you. Please read this post, and return with as much of the information as possible.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Indyana
Post by Indyana »
Hi, thanks for your reply. I have filled my profile with informations.
Source: Pinnacle LYNX 2 Vidéo
Product version: Ulead VideoStudio 11 + +Update Pack
Capture Options used:
Capture Frame rate : 30 frames/sec
Vidéo properties used:
Input source: Composite
TV System: SECAM_L1
Audio Input source : Microphone (correctly plugged with my VHS reader)
Output format for capture: I tried all format with same result
File properties generated for AVI output format 320x240,l420:
Images frequencies: 91 frames/sec
Vidéo sample size: 12 Bits
Vidéo compression : MS H.263
Thanks for your help!... :)
Sorry to keep asking for more info, but your video file properties just don't add up, especially if you're wanting to create DVDs from them.
Are you wanting to edit the video for DVD to be played back on set-top DVD players, for viewing over then internet or your PC, or some other? This is very important as the settings used during capture, editing and sharing depend on this.
You might want to read through From Camcorder to DVD tutorial.
A Recommended Workflow has been developed to help guide you through the mine-field of video editing, as it pertains to Ulead's VideoStudio Programs. They can be viewed here:
Recommened WorkFlow for VideoStudio
For a brief summary of AVI and MPEG-2 please read the article at this link:
Summary of AVI and MPEG-2
To better understand Field Orders, and Frame Based, please read the following article:
Explanation of Field Orders
Reading through the above, will give you a better understanding, that there is a lot more involvement to capturing, editing and producing DVDs..;)
Devil
Post by Devil »
Please read http://phpbb.ulead.com.tw/EN/viewtopic.php?t=29031 which is somewhat relevant.
However, I do see a potential problem with SECAM video streams: does your converter support this and what does it convert it to? Most devices support only NTSC and PAL.
Try to convert to 704 or 720 x 576, 25 frames/s
